Re: Farmall 140 front axle tube rotating problem.
Posted by Hugh MacKay on June 02, 2008 at 08:47:49 from (209.226.247.106):
In Reply to: Farmall 140 front axle tube rotating problem. posted by Randy Dragoo on June 01, 2008 at 19:46:51:
Randy: You have some good suggestions how to fix the holes and pins. The clamps should have fine thread grade 8 bolts, and you should have a wrench with 3' handle. I tighten those clamp bolts to point I could run the tractor without the center pin.
Even when new these center pins were not a tight fit. It was designed that way so you could adjust caster of front wheels. I have adjusted those so I could pop center pin out with my finger after clamps are tightened. Last winter when I painted my SA, it hadn't been apart for 12 years. I was able to pull those center pins starting them with a slight hammer tap and pulled both before I loosened the clamps.
