Re: What differences are there between a 1466 and a1566?
Posted by Aaron Ford on June 03, 2008 at 07:59:31 from (71.182.33.92):
In Reply to: What differences are there between a 1466 and a1566? posted by farmaboy on June 03, 2008 at 06:11:15:
I am intersted in seing an answer to this one too. I had always heard that the first numbers were the horsepower while the last number indicated the number of cylinders. Not sure if this is true because a local bulletin lists a 1066 as having more than 106. Not trying to hijack your post, but I will be following it.
Nothing like hearing those big diesels against a load.
Aaron
