Rev problem 300
Posted by MAGMAN on June 03, 2008 at 09:55:33 from (66.82.9.108):
I have got a small problem with this 300 if you put it in reverse and throw the clutch in it acts like you have the brakes locked? Only reverese and if you pull the TA back you can get it to move and pull the shifter out of rev .But if its running and in rev and the TA ahjead you can not pull the shifter at all either?
New Clutch pressure plate and such. I adjusted everything to the manual.
JON
