Re: Rev problem 300
Posted by mkirsch on June 03, 2008 at 10:33:50 from (64.80.110.50):
In Reply to: Rev problem 300 posted by MAGMAN on June 03, 2008 at 09:55:33:
Sounds like you didn't adjust the TA properly. They will bind and not allow you to shift if you don't get them right. Most TA linkages are quite worn by now, so it's more an art than a science to get them adjusted. You still use the measurements and techniques, but you need to fudge where you measure from due to the slop in the linkages.
