Posted by CWB on June 03, 2008 at 15:14:48 from (74.33.212.121):
tried to get my 1955 farmall 100 running again today after 3 or 4 years of sitting out. unfortunately, other projects got in the way but now its time for the restoration. problem is, i have no spark. its a completely original 6 volt system. my multimeter tells me that there"s voltage going to the coil and it has continuity from the coil through to the points. there"s also continuity through the main coil wire to the rotor, and through the spark plug wires. i carefully removed corrosion off the points with a file and touched up the studs on the coil itself. obviously im missing something, probably simple. can anyone help?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
