Posted by PungoFarmall on June 03, 2008 at 18:00:39 from (207.69.137.15):
Started my SA after an 8 month rebuild. Runs great but no charge on the ammeter meter. Needle moves to 2/3 amp discharge with ignition switch on. I search the archives and found the 5-step generator/regultor trouble shooting procedure. I was able to get the generator to charge by completing step 6; grounding the field post and jumping a wire from the VR BAT terminal to the GEN terminal. The gen started charging with 5 amps at full engine RPM. The charge rate fluxuated with engine RPM as it is suppose to. Drove around for a while with a good charging generator. But (there's always a but) after I shut the tractor off and restarted, the ammeter only showed a discharge again.
From what I read on previous posts, I think the VRs cutout relay is not closing for some reason and I may have to adjust the spring tension. Any advise?
6v positive ground system. Rebuilt gen. New regulator. Good grounds.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
