Posted by Janicholson on June 03, 2008 at 18:38:55 from (64.83.197.176):
In Reply to: SA Regulator posted by PungoFarmall on June 03, 2008 at 18:00:39:
With it running at 3/4 throttle, ground the field post on gen to a clean ground. If it begins charging, you may be needing to get a new new regulator. If no difference, but it begins charging when the Bat to gen is jumped, again a new regulator, or reduce the spring tension just a bit on the cutout. Disconnect the battery cable before removing the cover to avoid sparks. If it is new, it may be under warranty. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
