Re: DANGIT -Broken Bolt Help
Posted by KWSuperA on June 05, 2008 at 09:20:01 from (206.196.254.40):
In Reply to: DANGIT -Broken Bolt Help posted by Cub n M in OR on June 05, 2008 at 08:32:52:
I would get it out this way:
1. Drill a hole smaller that the diameter of the bolt directly through the center of the bolt.
2. Apply heat to teh broken bolt and area around the hole. Propane usually is not hot enough to do this job, an acetylene torch works best.
3. With everything hot use a squirt can of oil and squirt thru the hole in the bolt.
4. Tap your EZ out into the hole and remove.
5. If the bolt does not turn on the first go, do not force it. Repeat the steps and it should come out
