DON'T Use a (mis-named) Easy out!
Posted by Bob on June 05, 2008 at 09:31:53 from (69.178.228.68):
In Reply to: Re: DANGIT -Broken Bolt Help posted by KWSuperA on June 05, 2008 at 09:20:01:
DON'T Use a (mis-named) "easy out"!
The only result will be NOTHING (if you give up soon enough). Otherwise, you will be dealing with a broken easy-out.
In my 50 years the only times I have EVER seen an easy-out work is if the bolt is NOT rusted stuck in the hole, only sheared or twisted off, WITHOUT being rusted stuck.
I have NEVER seen a rusted-in-place bolt removed by one of the infernal things!
The "weld a washer to the broken stud, then weld a nut to the washer and allow it to cool before attempting removal trick" is by FAR your best bet.
