Bert: As far as your ignition problem - I don't know. But, as far as the carburetor - if that carb is totally clean (every tiny passage) and the float level is "dead on" and working, then you have an air leak somewhere. HALF CHOKE = LEAN. It is either where the carb bolts to the manifold, or where the manifold bolts to the head. Crank the M and take it up to mid throttle. While it is running 'rough', spray some WD-40 around the manifold-to-head runners at the head. If it smooths out, you've got an air leak there and you will need to remove the intake and have it planed off smooth at an automotive machine shop, then re-attach it with a new manifold gasket. Or, you may have a cracked manifold. If so, replace. Torque to 70 lbs.
Do you have a gasket between the carb flange and the bottom of the manifold? A good gasket? That is where I would check next for an air leak.
After that, check valve lash. It should be .017" @ hot.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
