Posted by Dr. Bert on June 07, 2008 at 14:15:57 from (72.36.57.176):
Installed a new 6 volt positive grd. VR this morning. When I start the tractor it will charge at a rate of 6 amps at moderate RPMs and almost 10 amps at high RPMs. However, when I shut the engine off (magneto ignition) the points on the cut-out portion of the VR will not open. Tried a different VR--same thing. Rechecked all the wiring, reread the VR installation instructions. Wire from the Batt. terminal on the VR runs to the hot side of the starter. What have I done wrong? Secondly, I have removed and boiled out the carburetor twice, checked the float level twice, replaced the needle and seat,but the engine still isn"t running right. Adjusted the power valve as per instructions, then the idle adjustment. Engine runs decently, but not smoothly. Smooths right out if I pull the choke out about half way. Obviously starved for gas, but I can"t figure out why. Removed the screen from the carb. gas inlet. Sediment bowl and fuel line cleaned. What else would you suggest? Thank you.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
