It is wired wrong, but there may be other issues as well. The wire from theBat terminal on the VR should go to the Amp gauge. It should attach to the side away from the terminal attached to the starter sw. I do not see how your gauge can read at all with the Bat term hooked to the starter (negative). It would charge, but not show on the gauge. while running (rewired to go through the meter) remove the F wire from the gen, then shut it off. if it still does it i'll be impressed. I think you have a regulator for a "B" type generator. They might feed current through the field (incorrectly) and cause the issue. JimN
