Re: M ignition and carburetor problems
Posted by teddy52food on June 07, 2008 at 15:11:59 from (209.237.111.169):
In Reply to: M ignition and carburetor problems posted by Dr. Bert on June 07, 2008 at 14:15:57:
The batt wire on the VR should go to the ampmeter, then to the battery. That way it would show discharge when you shut it off and the cutout points stay closed. Make sure the regulator is grounded good.
