Re: how should a Farmall H run?
Posted by Steven f/AZ on June 07, 2008 at 16:39:42 from (24.121.155.84):
In Reply to: how should a Farmall H run? posted by bgarrett on June 07, 2008 at 11:07:04:
Was thinking about this some more... pull the side cover off the governor (about six or eight bolts) and watch while someone moves the throttle lever back and forth (engine off, of course) and see what moves. There should be the lever going into the governor from the throttle moving, and a shaft moving/turning that goes back to the carburetor.
If there aren't parts moving in there with the throttle, you have stuck linkage.
If those parts move, then inspect the pieces in there to see if anything is loose or broken.
I had trouble with my W-9 governor being sluggish and then going to full throttle suddenly - took it apart and the bearing fell apart as soon as I tipped it sideways!
