Re: 424 charging issue
Posted by IntHarv on June 08, 2008 at 11:58:23 from (69.27.61.226):
In Reply to: 424 charging issue posted by BlakeinTN on June 08, 2008 at 10:05:20:
when you put the negative on the battery pos and the pos on the generator all you are doing is getting the battery voltage. It may say -12.4 since you are reversed. You need to check the voltage coming off of the terminal of the generator that goes to the bat. Put pos on that pole and ground it on the chassis somewhere. That will tell you how much your generator is putting out.
