Re: 806 Power Steering
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by SDman on March 13, 2000 at 16:58:49 from (63.83.208.93):
In Reply to: 806 Power Steering posted by Ken T on March 13, 2000 at 15:03:29:
Ken, I usually have a couple of 06 through 66 Series do this every year. First thing you can try is this: look at your MCV, on the rear side(the side facing the drawbar end of the tractor) of that MCV you will find an electrical sending unit. Underneath that, you will see 2 plugs screwed into the valve. Screw out the smaller one(5/8" wrench size if I remember right). Crank the engine over briefly & see if oil comes out of that plug. If it does, put the plug back in & see if your steering works now. Most of the time, the power steering pump wears internally enough so that it cannot prime itself when it cannot produce power steering. The pump has to share the filtration with the rear pump that runs the remotes & hitch. What can happen is that the rear pump, because it is only a foot away from the filter, can actually pull oil away from the front pump through the filter. With a weak front pump, it cannot prime itself & have the problems you are describing. If you want to live with it, you can probably just remove the plug like I describe. If you want to really fix it, you will probably have to replace the front pump. This problem was remedied on the 86 Series with a supercharge line that hooked the 2 pumps together somewhat eliminating this problem. Hope this helps.
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
