Re: 424 charging issue
Posted by Brownie 450 on June 08, 2008 at 17:11:32 from (216.51.158.151):
In Reply to: 424 charging issue posted by BlakeinTN on June 08, 2008 at 10:05:20:
If you can get to your regulator, --Assuming a negative ground system--- clip your meter's negative lead to the negative batt. terminal or ground & check for battery voltage at the "BAT" terminal. If this is 12.4 or thereabouts, with engine running, short the "F" terminal on the generator or regulator to ground. If voltage picks up to 13 volts or more, the regulator is at fault. If voltage doesn't improve, I'd suspect worn generator brushes or other generator problems.
