Re: 424 charging issue
Posted by Brownie 450 on June 08, 2008 at 17:17:57 from (216.51.158.151):
In Reply to: 424 charging issue posted by BlakeinTN on June 08, 2008 at 10:05:20:
The ARM. terminal on the generator should be connected to the GEN. terminal on the regulator. The "F" terminal on the generator should be connected to the "F" or FLD terminal on the regulator. If you suspect wiring troubles, use 2 jumper wires to by-pass the regular wiring from gen. to regulator.
