Re: 460 hydraulic pump question
Posted by bjc on June 09, 2008 at 19:10:53 from (75.107.152.63):
In Reply to: Re: 460 hydraulic pump question posted by J.J. from Afton on June 09, 2008 at 18:50:38:
thanks, does it sound like the pump? i just had the lift cylinders rebuilt and this is the first time i really worked it hard.
i did up down thing a bunch of times to get all the air out. so i dont think its air in the cylinders.
i am going to take it apart and change the filter and check things like that before i try to replace the pump.
thanks again
