If chanding the filter and what not doesnt make a difference it most likely sounds like th pump is the problem, or a blocked or clogged line between it and the valves, or in the valves themsevleves. Could also be worn o-rings on the pump or supply tube. The other thing that happens is the constant running shaft drving the pump will wear, or strip out, but than the hydraulics usually go out all together. Let us know how it goes for ya.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
