Posted by Andrew Z on June 10, 2008 at 09:50:36 from (12.76.152.219):
I was trying to look up how to hook up a 3 wire to the alternator but i have a Mag and im not sure how to do it, i did try to wire it up with out the use of a switch i just went right to the amp meter but that does not seem to work. Iv also noticed that i can get it to charge by just touching one of the terminals on the amp meter to a ground and that will make it charge right up. could i have a bad meter? or a bad ground on the meter? or do i have to make a ground from the meter to the ground? i have clean terminals and connections brand new battery. Im a little lost here, i have never had a problem like before.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
