Re: Charging..... I think i got it
Posted by Andrew Z on June 10, 2008 at 11:23:05 from (12.76.153.133):
In Reply to: Charging..... but not 100% posted by Andrew Z on June 10, 2008 at 09:50:36:
First off thanks for everyones help here, i realllly appreciate it! I got it to charge by hooking the exciter wire to the battery to excite it. However.... it charges 17 volts!!!.... I think i need to hook up a external regulator to it? Im going to have to wire up a switch so that i will be able to kill the power to the alternator and not drain the battery.
Thanks Veryyy much again!!
Andrew
