Re: IHC 766 Auxillary Valves Problem
Posted by karl f on June 10, 2008 at 12:14:51 from (64.83.221.111):
In Reply to: Re: IHC 766 Auxillary Valves Problem posted by TWilliams on June 10, 2008 at 06:29:49:
those adapters could still be your problem. maybe you should get the IH ends on your hoses, at least one pair to test. If it works, then drop the 130$ on the valve conversion kit for the tractor, or switch the other hoses to ih ends.
you have the levers in the right position on your valve assy right?
karl f
