Re: 12 conversion
Posted by Ludwig on June 11, 2008 at 07:02:42 from (63.209.233.26):
In Reply to: 12 conversion posted by GIfarmer on June 11, 2008 at 06:25:58:
What kind of starting problems?
When I've got a good 6v battery (which I don't right now, mine is almost 10 years old) my Super M starts plenty easy with 6v.
If it won't start good with 6v you might (probably) have another issue that a 12v starting system will just be masking. I'd hate to think you putting in a bunch of work going to 12v and burning out the starter because you've got to grind away on it to get the tractor to start.
Does it start easy if you pull start it?
That said I see the 12v as a big advantage in allowing you to put in electronic ignition much less expensively. Or rather a 12v electronic ignition was alot less (like $100 less) expensive than 6v the last time I checked.
