Re: 12 conversion
Posted by rustyfarmall on June 11, 2008 at 07:18:04 from (209.152.78.71):
In Reply to: Re: 12 conversion posted by Ludwig on June 11, 2008 at 07:02:42:
I agree. If all is well with the 6 volt system, that tractor will crank up and run just fine. If all is NOT well, 12 volts might be a temporary cure, but the problems will eventually resurface.
