Re: Super M charging/wiring issue
Posted by Janicholson on June 11, 2008 at 10:42:11 from (199.17.6.122):
In Reply to: Super M charging/wiring issue posted by Ludwig on June 11, 2008 at 07:08:53:
First replace the battery.
Then see if it charges well (needs to be at 1/3 throttle to charge well)
if not replace the regulator.
Then when it is operating correctly charging, replace the wiring harness, or build one using soldered on connectors, and shrink tubing.
Use color code, and photo the process. Also make a diagram showing color and connections.
Good luck, JimN
