Re: Plumbing loader on 300 Farmall
Posted by mkirsch on June 11, 2008 at 15:05:54 from (67.240.251.254):
In Reply to: Plumbing loader on 300 Farmall posted by Hugh MacKay on June 11, 2008 at 09:07:16:
Is a Tee is the proper connection to make here? This is an open center system.
If you simply tee off the high pressure line, you create two paths for the oil to get back to the reservoir, and the oil will always take the path of least resistance. Pull the lever on the loader back, and the oil will just flow through the stock valve stack, and back into the reservoir without raising the loader. To get the loader to work, you will need to hold back one of the stock valves to block the second path while operating the loader, and release it when you release the loader valve to prevent the pump from overheating as it squirts the oil through the relief valve.
My understanding is, you want to connect the loader valve stack IN-LINE with the high pressure line. Pump to IN, Power Beyond to the tractor's stock valve stack, and OUT to the fill port on the reservoir.
