Re: Plumbing loader on 300 Farmall
Posted by Hugh MacKay on June 11, 2008 at 18:34:09 from (209.226.106.44):
In Reply to: Re: Plumbing loader on 300 Farmall posted by mkirsch on June 11, 2008 at 15:05:54:
mkirsch: I guess I best spell it out exactly how I did that plunbing. I cut my high pressure line, a welder brazed hydraulic fitting on each end. Power from the pump went into power beyond valve. The discharge from the power beyond valve hooked back into high pressure line going on the the 300 factory valve tower.
I used it that way close to 20 years. It gave me 5 instant remote valves, Bear in mind one could only use one maybe two if small demand, at any given time, 300 just doesn't have the GPM for much more. I had my loader hooked to the power beyond valve if it was on tractor. I could also use any one of 300s 3 factory remote valves at any time, my only limit was GPM.
