Posted by tj in iowa on June 11, 2008 at 19:36:34 from (67.1.113.244):
I have a IH two way on my M, but it only works good with the rod forward. I have two rods, one turns on the pump, and you can lock it back, the other is the two way, works when you push it forward, at times it works both ways, then all the sudden it won't. The fluid is up to level, and it doesn't matter if I use a one way or two way cylinder. I can move the cylinder all the way out, then have to swap hoses around to get it back in. Some times if I shut off the pump the cylinder will go back in if there is weight on it. But it will work good sometimes and then all the sudden you hear a little click near the couplers and it won't go the one direction at all. Is it possible to have bad couplers, or maybe something plugging the coupler? I took apart the two way valve and it was clean as a whistle. Hope to start cutting hay with it as soon as weather will let me. Thanks guys you are always a good help.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
