Re: M 2 way Hyraulic
Posted by mkirsch on June 12, 2008 at 05:55:17 from (64.80.108.52):
In Reply to: M 2 way Hyraulic posted by tj in iowa on June 11, 2008 at 19:36:34:
Clean really doesn't tell you much. It could be clean but worn and not operating correctly.
What happens if you get off and operate the valve's lever manually, bypassing the rod? Does it feel the same in both directions, or does it snap, pop, or feel "mushy" in one direction?
When you hear that click, try to reconnect the hoses. You may not have them connected properly, or as you suspect, the connectors may be worn out.
To lower one-way cylinders with the two-way valve installed, you need to release the belly pump rod. That's normal.
