Farmall H charging?
Posted by tractorsam on June 13, 2008 at 14:16:20 from (142.68.41.53):
I recently installed a new generator on a Farmall H. The owner had installed an 8 volt battery shortly before and installed it as negative ground. I don"t know what"s on it for a regulator. I installed the generator without noticing about the battery. After I polarised it I checked the voltage of the battery 8.15 with the tractor off and 8.5 running. Also the ammeter doesn"t work. Should I be concerned about the reverse polarity or just take it as working and leave it how it is? Many thanks, Sam
