Posted by John T on June 13, 2008 at 17:40:13 from (66.244.97.31):
In Reply to: Farmall H charging? posted by tractorsam on June 13, 2008 at 14:16:20:
Whether or not an old 6 volt system will charge an 8 volt battery DEPENDS on the VR it has (and if it can be tweaked). Generally if its a 2 wire Cutout Relay it can charge at 8 volts no mods needed. Im like Jim if it raises the battery voltage from its normal 8.4 volts to over that when shes at RPM Id just live with it a while. Make sure the belt is good n tight and if its a 3 brush genny Id adjust it for max charge.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
