M tractor with water in motor oil
Posted by Duane Schweigert on June 14, 2008 at 14:34:26 from (216.67.169.213):
This started a year ago when I found radiator fluid in crankcase when changing motor oil in the spring. Went ahead and changed oil, ran tractor all summer (checking oil constantly) and didn"t have any water. Drained radiator in the fall and in the spring again had water in crankcase. Changed the oil, filled radiator and ran tractor for 8-10 hrs and had water in the oil. It was suggested that I try checking headbolt torque as a first step before getting further into the motor. Went up to 70 lbs. and had some bolts turn 1/2 to 3/4 turn before torque wrench broke over. Now wonder what the recommended torque is. Can I go higher? Any other suggestions?
