Re: M tractor with water in motor oil
Posted by CHIEFEAVES on June 16, 2008 at 07:56:07 from (205.188.116.73):
In Reply to: M tractor with water in motor oil posted by Duane Schweigert on June 14, 2008 at 14:34:26:
If tighting the head does not work, may want to pull oil pan and check around front main bearing. I ahd a leak and it was coming from a rusted out freeze in the front of the block behind the plate that mounts to the front of the block. I used a flashlight and spotted the water bead there close to the front main. Harley
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
