F20 clutch fixed Radiator ht on top cold on bottom
Posted by Bill Thompson on June 14, 2008 at 18:32:25 from (204.13.113.181):
I got all the mice stuff out and adjusted the clutch. After lifting bell housing up 15 times to align shaft I found that if you keep the clutch loose and spin housing around you can align the shaft and tighten clutch bolts thru inspection plate. Tractor moves great but governor is not working and the radiator is very hot on top but warm on bottom. I did flush the mice nests out before adding antifreeze. How do I fix governor and throttle speed? Thanks, Bill
