Re: F20 clutch fixed Radiator ht on top cold on bottom
Posted by Mark Poss on June 14, 2008 at 20:35:45 from (12.207.29.222):
In Reply to: F20 clutch fixed Radiator ht on top cold on bottom posted by Bill Thompson on June 14, 2008 at 18:32:25:
With a thermo-siphon system you must mix the water and anti-freeze together before adding it to the radiator, otherwise if you put the anti freeze in first you will cause a block, not allowing the anti-freeze and water to circulate.
good luck!
