Re: IH3588 2+2 No fuel out of injectors after sitting, clog
Posted by qboneus on June 15, 2008 at 09:49:57 from (72.175.1.182):
In Reply to: Re: IH3588 2+2 No fuel out of injectors after sitting, clog posted by Dave in Tx on June 15, 2008 at 07:51:34:
So are you saying I should charge the fuel filters at least partially with atf when I get the injectors back in?
or should I just let it pump atf through it BEFORE I put the cleaned injectors back in to clean the pump and lines without washing my cylinders down with atf(if it matters)
I cannot find an electric pump anywhere despite the fact that my IH dealer said there could be one.
I even pulled the rear hood piece and the bellows assembly so I could examine the tank in-depth and can find no electrical connections to the fuel tank other than the tank level sender, and there is no inline electric after examining all lines betwixt the tank and filter assemblys.
If the return line is pulled and cranked like you describe what would I see when I crank the tractor?
I had liquid fuel under some pressure when I disconnected mine to examine the injectors.
Thanks for your time and expertise.
Tal
