Re: IH3588 2+2 No fuel out of injectors after sitting, clog
Posted by Dave in Tx on June 15, 2008 at 07:51:34 from (71.121.99.189):
In Reply to: Re: IH3588 2+2 No fuel out of injectors after sitting, clog posted by Qboneus on June 14, 2008 at 22:56:29:
very possible the fuel throttle valve is stuck in the pump. or the solenoid is not working if electric. pull the return line loose at the injectors where the return line goes to tank, and crank. will tell if clogged return line. I work with a lot of diesels that have sat a long time, and throttle valves on rotary pumps and delivery valves on inlines will be stuck enough they won't advance to start. Atf works the best for me to loosen them.
