Posted by Allan In NE on June 16, 2008 at 15:41:16 from (148.78.243.26):
Got a problem; not great, but it is just driving me crazy 'cause it just isn't "right".
A little slop between the pitman arm and it's gearbox shaft. Would probably outlast me the way it is, but it just bothers me.
The shaft is roughly 1 1/8" in diameter, splined and TAPERED. Splines are not quite as big as a 540 PTO shaft and roughly 1 1/4" to 1 1/2" long.
Anyhoo, over the years, this thing has been allowed to get loose and wobble the cinch fit out a bit. Not "real" bad, but enough that I just don't wanna trust it.
I can't just "washer it up" on the taper, because then the pitman arm would be too close to the gearbox and would hit the cover bolts.
How in the heck can I tighten that taper-fit up? Maybe "shim" it with a wrap of tin foil in and around the shaft splines?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
