Re: Need Your Collective Brain: HELP!
Posted by IaGary on June 16, 2008 at 15:52:50 from (207.177.17.200):
In Reply to: Need Your Collective Brain: HELP! posted by Allan In NE on June 16, 2008 at 15:41:16:
We would tighten up some at the weldshop with splatter.
Take a 12 volt battery a set of jumper cables and an old hacksaw blade.
Hook one end to the shaft.
Hook the other to the hacksaw blade and drag it long the shaft.
It will leave real fine burrs that tighten it up wear in shafts where the bearings ride. Should help your splines also.
Works good.
