Re: starter trouble
Posted by Janicholson on June 18, 2008 at 16:58:46 from (64.83.197.176):
In Reply to: starter trouble posted by jeeper55 on June 18, 2008 at 14:14:51:
The stud is eroded away some. There are three things to try.
1) elongate the holes in the switch to allow it to be forward about 1/16". this allows a bit more operation out of a worn stud.
2) Repair the stud by silver soldering a thin strip to the surface that hits the contact in the switch. (requires disassembly of starter to prevent melting of the insulator, (probably a pro job unless you are setup for serious soldering.
3) replace the stud Same as 2 above. JimN
