Re: super c VR issues
Posted by Janicholson on June 20, 2008 at 07:25:30 from (66.173.50.123):
In Reply to: Re: super c VR issues posted by mazemeister on June 20, 2008 at 07:05:26:
Bending the tab has been common for several years on some VRs. Care bending is also reason to disconnect Bat when getting serious.
The Cutout depends on more than about five amps discharge to click off. Even then the meter will still show discharge from the ignition system (if coil equipped). The slower it turns, the longer the points are closed in the dist, resulting in higher current draw in the system (not much, but it will show) Try bending the VR relay spring a tiny bit. JimN
