Posted by mazemeister on June 20, 2008 at 07:05:26 from (24.188.81.230):
In Reply to: Re: super c VR issues posted by mazemeister on June 20, 2008 at 05:07:05:
the D-R tag on the genny says 1100501 4?30 can't quite make out the ? digit, might be C,G,O, or zero. anyway the parts book lists 1100501, and a 3rd brush.
on the VR ground- tried a jumper wire from the little copper wire on the VR that goes from the base to the mounting tab, to the tractor frame- didn't help at all. the F to FLD wire idea sounds worth a shot- i'll see where i get with that. The new VRs these days don't have any adjusting screws for the spring tension, and it seems like the past few i've gotten were not set at correct voltage- so i guess they (NAPA or whoever) expect us to just bend the tabs to adjust?
Just did 2 hrs of cultivating, ammeter stayed right at -1 even at high idle. low idle dropped down a couple more. would that suggest the cutout relay also needs adjusting? I thought that was supposed to cut out to prevent discharge.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
