I ONLY USE THE 2 POINT TO TOW 4 WHEEL HAY TRAILER WITH, DO NOT USE THE REMOTES AT ALL ONLY USE THE POWER STEERING,IS THERE A SPECIAL WAY TO BLEED THE AIR OUT ? WAS WORKING BEFOR I DRAINED THE SYSTEM AND REFILLED WITH HIGH-TRAN FLUID DAN S
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
