Re: 350 utility HYDRA- TOUCH SYSTEM
Posted by homard on June 20, 2008 at 11:31:11 from (214.3.92.171):
In Reply to: 350 utility HYDRA- TOUCH SYSTEM posted by DAN S on June 20, 2008 at 09:50:33:
Before you changed to Hytran, did the hydraulic system work?
If I understand correctly, there is fluid flowing through the system (can bleed it out of the taps), it just will not building pressure. It sounds like something is wrong with your safety valve-pressure regulator (stuck open, blown O-ring).
Was the system recently put under a lot of stress (tried to pick up something VERY heavy)?
