Re: Model M serial 137869 x1
Posted by Andy Motteberg on June 21, 2008 at 17:28:42 from (4.143.217.247):
In Reply to: Model M serial 137869 x1 posted by John Cambern on June 21, 2008 at 09:16:30:
Use 80-90 Gear Lube in the Transmission and 30wt in the engine, or 10w40 will work in the engine. The steering sector gear is lubricated with oil and should also be checked. The belt pulley housing (if your has a pulley) holds oil too. I don't have a M manual to tell you how much, you should buy a manual.
Andy.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
