Re: Model M serial 137869 x1
Posted by mkirsch on June 21, 2008 at 20:17:12 from (67.240.251.254):
In Reply to: Model M serial 137869 x1 posted by Andy Motteberg on June 21, 2008 at 17:28:42:
The steering gear housing's seals are probably shot. If you add oil it will probably just leak out and make a huge mess.
It's true that it should have gear lube in it, but most have packed them with axle grease due to the difficulty in keeping the gearbox sealed.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
