Re: back firing
Posted by Janicholson on June 22, 2008 at 09:56:37 from (64.83.197.176):
In Reply to: back firing posted by lbm on June 22, 2008 at 09:39:37:
Probably the rubbing blosk of the distributor points is worn and there is no dwell. Open the distributor cap, pull out the rotor, (and then the dust cover if it has one). The dist. cam has four lobes, turn the engine until one of these (any) is directly under the rubbing block, and then adjust the points to .020". If it has a mag, let us know, there are different instructions. It could be a coil proble, or a bad condenser, but check the points first. Jimn
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
