Brad - If the ballast resistor is new, a few wisps of smoke from it the first time it's powered up is normal. (The resistance coil inside gets very hot in normal operation. The smoke is oil, etc. from the manufacturing process burning off the coil...)
Does't matter if the ammeter is wired backward. The meter will read "backward" but otherwise will operate normally.
Presuming you have a standard Delco 10SI (not a "one wire" 10SI) it won't work unless you have connections to both the #1 and #2 terminals.
#1 needs to be supplied from the ignition switch thru either a warning lamp, an equivalent resistor or a diode. #2 can be pigtailed directly to the alternator's output terminal.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
