Posted by Bob M on June 24, 2008 at 08:38:31 from (151.190.254.108):
In Reply to: Super H electrical posted by aaachris on June 24, 2008 at 07:36:12:
Like Jim points out below the 6 volt Super H does not use a resistor.
As to your points burning problem, also as Jim mentions the cause can be a bad condenser, bad coil (draws too much current) or oil contamination on the points.
Point contamination is easy to spot. To narrow it down between condenser and coil, observe the ammeter with the ign switch "on" and the engine stopped. If it reads more than 3 - 4 amps discharge the coil's drawing too much current and overloading the points. Otherwise suspect a bad condenser. (Just because both coil and condenser are new doesn't mean they're good out of the box - especially if they came from China!)
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
